Cleaning up two intersecting walls
3 REPLIES 3
mrdavie
640 Views, 3 Replies
Attached are two screen captures of two walls intersecting. Both walls have 6 in. metal studs with 5/8 in. gyp bd on the interior and 1/2in plywood sheathing just outside the exterior core. The exterior core is the location line for the walls.
Image A shows the vertical oriented wall stoping short of the horizontal wall. I would expect to see the studs and interior gyp bd wrapping cleanly.
Image B shows the end of the vertical wall pulled down just past the horzontal wall. the brick veneer comes throubh. I want the brick veneer to stop just short of the sheathing on the horizontal wall.
(Don't forget to use the backspace key to close the images. If you 'x' out you will be exited from the browser ((at least that's what happened to me!))).
3 REPLIES 3
mrdavie
in reply to: mrdavie
I just realized that the walls cleaned up at the other end. I don't know why it would be different (see Image C)
David_W_Koch
Are the two Wall types identical, except that the horizontal one does not have brick and air space?  Your "A" image shows that Wall Join has been disallowed for the vertical Wall.  If I do the same here with similar Wall types, I get the same results.  If you want the Walls at the "A" end to cleanup like the ones at the "C" end, select the vertical wall at the "A" end and click on the Allow Join grip (blue, "hollow" T-shaped grip, on its side in your image).  You may have to use the Trim tool to get the desired alignment of Wall endpoints/cleanup.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
mrdavie
in reply to: David_W_Koch
That was it! I don't know how they became unjoined. Thanks!
Rail Community
