Changing the sheet border to another
3 REPLIES 3
krybuk
2575 Views, 3 Replies
I created many sheets with a wrong border, can I reassign another  titleblock instead of making all new sheets from scratch?
3 REPLIES 3
in reply to: krybuk
Yes. Click on the Titleblock in a Sheet, then in Properties you should be able to select another Titleblock Family--which should be loaded into the Project first.
krybuk
Thanks! How did I miss that?
scott_d_davis
in reply to: krybuk
and if you did many sheets: right click on one and choose Select All Instances, and then choose another loaded titleblock from the Type Selector in Properties.  No need to do them one by one.
Scott D Davis
Sr AEC Technical Specialist
