Revit Architecture
Valued Contributor
krybuk
Message 1 of 4 (334 Views)
Changing the sheet border to another
334 Views, 3 Replies
01-04-2013 09:24 AM
I created many sheets with a wrong border, can I reassign another  titleblock instead of making all new sheets from scratch?
Yes. Click on the Titleblock in a Sheet, then in Properties you should be able to select another Titleblock Family--which should be loaded into the Project first.
ccollins
Message 2 of 4 (329 Views)
Re: Changing the sheet border to another
01-04-2013 09:35 AM in reply to: krybuk
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Valued Contributor
krybuk
Message 3 of 4 (322 Views)
01-04-2013 09:47 AM in reply to: ccollins
Thanks! How did I miss that?
Employee
davissc
Message 4 of 4 (311 Views)
01-04-2013 10:57 AM in reply to: krybuk
and if you did many sheets: right click on one and choose Select All Instances, and then choose another loaded titleblock from the Type Selector in Properties.  No need to do them one by one.
Scott D Davis
AEC Technical Specialist
North American Sales
Want Revit Content? Go to http://seek.autodesk.com !
