Changing .pat scales
1 REPLY 1
vanderloo5
480 Views, 1 Reply
Can someone refresh me on where I need to go to change the scale of a fill pattern. I have brick walls that the brick facade scales about 1/2 of what it should be.
1 REPLY 1
Lance.Coffey
in reply to: vanderloo5
After reviewing the following forum post, it looks like you can set the Import Scale of the PAT file when you import it into your Fill Pattern:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Revit-pat-files/td-p/1989161
Lance Coffey
Technical Support Specialist
