Changing door swing direction in a downloaded toilet stall family.
9 REPLIES 9
Message 1 of 10
doni49
3162 Views, 9 Replies
Hi All!
I downloaded a toilet stall that looks pretty good.  But the door swing is on the wrong side for my plans.
Short of starting from scratch, is there a way to change the hinge side?  Some restrooms have the hinge on the right side and others on the left.  I'd like to be able to change this via a parameter.  If I could figure out how, I'd add the param to the family.
The stall family in question:  http://seek.autodesk.com/product/locale/adsk/revit/families/arch/empty/Revit_ARC1774
TIA!
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
9 REPLIES 9
Message 2 of 10
Jason_S
in reply to: doni49
I modified that partition awhile ago.  See attached...
Hope it helps you out.
Message 3 of 10
doni49
in reply to: Jason_S
Thanks.  I'll try it out tomorrow morning.
Don Ireland
Message 4 of 10
doni49
Thanks.  It does look a lot nicer.  BUt it still won't allow me to change the door swing from left to right (or vice versa as I don't remember off hand which way it currently swings).
Don Ireland
Message 5 of 10
Jason_S
in reply to: doni49
Use the Flipper arrows to flip the door from left or right after you select how you want the partition.  See attached
Message 6 of 10
doni49
Yes.  I tried that that this afternoon.  But when I flip it, the entire unit flips -- not just the door.  THis means that I now need to change the visibility params to change which walls are off.  But that causes other ones that I've already placed to change.
Don Ireland
Message 7 of 10
Jason_S
in reply to: doni49
Well the other way to do it is create the door and swing as a separate family insert it and then control the door family with the display parameters.
Hope you can tweak it to what you need.
Message 8 of 10
doni49
Thanks.  I was able to tweak it -- it was a great starting point though and I appreciate that.
I've attached my version in case you or anyone else want(s) it.
I eliminated one of the swing visibility tests (since I only one inside OR outside and never both, if inside is off then I want outside).  And I added a Door Left Hand visibility test.  I also made both instance params because these options vary from one RR to the next.
Lastly, I created four yes/no params that all work based on formulas and THEY control which door shows up.
Don Ireland
Message 9 of 10
doni49
in reply to: doni49
I tweaked a little further and copied it for use as an "Accessible Stall" as well.
Don Ireland
Message 10 of 10
doni49
in reply to: doni49
Duh!  I uploaded the wrong "Accessible" family.  What I put up there is what I WAS trying to make work previously.
Here's the correct version.
Don Ireland
