Hi everyone.
I'm working on a project with MDF panels on the walls. In some cases, these panels will also line the ceiling. Since I can't make a curtain system horizontal, I used sloped glazing and just made it flat. This has worked very well, for the most part, except now I want to be able to tag it as "ceiling" in my RCPs, but, of course, Revit sees it as a roof, not a ceiling. Is there a way I can just change the category of these individual elements just so that they're tagged properly? And if not, is there a way to just force the tag to fib?
First time poster, thanks so much in advance!
-Schuyler.
You say you can"t make a Curtain System Horizontal ? In wich version of Revit do you work?
In R2013 and R2014 you sure can...
If you make an In Place Mass form Massing and Site ...an extruded rectangular shape and then apply Architecture >Build> Curtain System> you can place this to vertical and horizontal faces...
