change the height Ceiling plane
4 REPLIES 4
GHASEM_ARIYANI
2775 Views, 4 Replies
hi
How We can to change the default height Ceiling plane In Project Browser.
For example, the Default is 2600mm.
I want to Over 2800mm  set.
Not in Time Drawing Ceiling.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 REPLIES 4
CoreyDaun
in reply to: GHASEM_ARIYANI
What you're showing in your image is the Reflected Ceiling Plans - the Ceiling Types are further down in the Project Browser; under Families » Ceilings. But that's a mute point, because the Default Ceiling Height is not stored within the Ceiling Type, and therefore, it is not accessible through the Project Browser.
In order to establish a new Default Height, activate the Ceiling command and, before creating the Ceiling, enter the desired value under Properties. This will become the new Default Height for ALL new Ceilings, regardless of their Type.
GHASEM_ARIYANI
in reply to: CoreyDaun
Hi
Thank you for the reply
I may It Exist Be As Height  Floor Plane We can to height  Ceiling plane
We also changed.
jonasdodd
It is a moot point, not a mute point.
sakar_deepak
in reply to: jonasdodd
Hi @jonasdodd
Could you solve the puzzel put up by dear @GHASEM_ARIYANI
" I may It Exist Be As Height  Floor Plane We can to height  Ceiling plane
We also changed. "
What does it mean ?
Regards
Deepak Gupta
Architect
(...... those, who are answering the problems in community forum here, are great people .....)
Rail Community
