Change Height of One End of Wall
2 REPLIES 2
PhilvK
4397 Views, 2 Replies
Is there a simple way of raising one end of a wall to get a sloped top? Please see attached.
2 REPLIES 2
SteveKStafford
in reply to: PhilvK
Select the wall, click Edit Profile. You can change the shape/sketch of the wall to match the slope required. If the is a roof over that then you could use Attach to extend the wall up to the roof. It can also be used with a reference plane assuming one is present, say in an elevation view.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
select the wall you want to change > Mode > Edit Profile - once entered in Sketch Mode draw the wanted profile > Finish Edit Mode...
Constantin Stroescu
