Ceiling Question
3 REPLIES 3
revitman91
281 Views, 3 Replies
Ceiling Question
Hi, I am trying to figure out why I have no ceiling when I change the height from 8'-0" to 9'-0". Soon as I change it, my ceiling disappeares where all I can see is the roof from the inside. Also, the ceiling in two rooms seemed to have stayed in place at the 9'-0" height, but I can't place any lighting fixure in the ceiling unless I make it 8'-0" again... Any help will be much appreciated. Still learning this softwear.
3 REPLIES 3
rosskirby
in reply to: revitman91
Go to the properties of your RCP, and make sure that the view range is set so that the view extents go beyond the highest ceiling, otherwise it won't be visible in the view.  Rather than trying to figure out exactly what height to set it at, just change it to unlimited, and click Apply.  You should see the ceiling then.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
revitman91
in reply to: rosskirby
That did the job! Thank you.
rosskirby
You're welcome.  Glad I could help.  View ranges can be tricky.
Ross Kirby
Principal
Dynamik Design
