Revit Architecture
gmak
Message 1 of 2 (79 Views)
Ceiling Plans
79 Views, 1 Replies
05-24-2004 09:04 AM
In some of my reflected ceiling plans my walls have disappeared. I'm sure it has to do with the View Range, but I can't seem to get the walls unless I set the Cut Plane to something like 100mm, which means I don't cut through windows.
If I have a floor to floor of, say, 3000mm. What would you suggest as the settings for the View Range?
thanks
*Aaron Rumple
Message 2 of 2 (79 Views)
Re: Ceiling Plans
05-24-2004 09:34 AM in reply to: gmak
I set my cut plane for plan and rcp at the same 4'. You can use the plan region to define a unique view range for any area that needs unique setting. I however prefer true cuts for my plans and rcp's. If a ceiling doesn't get cut by the cut plane - I don't want it shown. "gmak" wrote in message news:682099.1085414717053.JavaMail.jive@jiveforum2.autodesk.com... > In some of my reflected ceiling plans my walls have disappeared. I'm sure it has to do with the View Range, but I can't seem to get the walls unless I set the Cut Plane to something like 100mm, which means I don't cut through windows. > > If I have a floor to floor of, say, 3000mm. What would you suggest as the settings for the View Range? > > thanks
