I am at a university where we are trying to use a commerical revit file of a new building on campus (ours) to illustsrate a completed project - or near completed project. The idea is that they see the relationship of the actual project file and the project as it is completing. However, the project file will not open in the revit we have insatlled in our educational lab. We do have access to one commercial license and it opens just fine in that. The versions are installed from the same installation files - the only difference between versions is the product key and the serial number. Is this normal behavior? Can I somehow alter the commercial file so it will open with the educational versions?
Thanks for any help.
Solved by terry. Go to Solution.
DarrenP
Well sort of. And it has nothing to do with revit but with my brain. After trying to open a number of revit files and breaking for dinner, I came back and tried to open another type of file on the same drive. I soon realized that the drive had become disconnected and that the message that revit could not open the file really meant that revit could not find the file. It is now fixed and the answer to the question is, yes, Revit educational can open files created by Revit Commercial.
Thank you much for responding.
