Show only
Search instead for
Cannot divide to zero error on REVIT to JSON exporter development
I am trying to write a custom exporter for Revit to JSON. I have seen a similar example code of Custom exporter for ADNMESH to JSON.
When I tested it for a sample RAC Basic file for Revit 2014, I got an error of Cannot Divide by zero. After debugging the code found that the Centroid and volume for few objects is 0 which is causing the error. Please can anyone let us know what is the solution for this issue? Is there any other example to do this?
We are using the code available at the following link:
