Has anyone encountered this issue before? I have a project with straight and curved grid lines. These grid lines exist in another model that is linked. When I try to select them to copy monitor, I can select all of the straight grids, but I cannot select the curved grids! I know I can simply copy them from one project to the next, but I would prefer to copy monitor them at this point.
Solved by CoreyDaun. Go to Solution.
I tested in Revit 2014 and I was able to Copy/Monitor a curved Grid just like any other. There may be another factor in play, here; can you TAB+Select that Grid?
Sorry, I wasn't clear. This is more than a curve. It is multi-segmented in the sketch, with straight segments and curved segments. As far as I can tell, this is the issue, not curves, but multiple segments.
OK. It seems to be the case that the Multi-Segment Grids simply cannot be the subject of Copy/Monitor, whether or not they contain curved segments.
