Cannot change dimensions !
4 REPLIES 4
popguyon99
9293 Views, 4 Replies
here attached with a picture captured my current issue, can somebody please help me??
actually, the object is just a simple extrude, i don't how to make the dimensions editable, please help
4 REPLIES 4
AJA14
in reply to: popguyon99
To be able to make dimensions editable, you need to select the object and not the dimension. When you do, the dimension turns blue and then you can click on the text and edit it.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
popguyon99
in reply to: AJA14
so, i cannot build dimensions onto the drawing directly, and change the sizes by modifying the numbers?
AJA14
Yes you can. But to modify the dimension, you need to select the element that the dimension is driving, then click on the dimension text and it becomes editable. When you change the text the element follows.
Ali Al-Hammoud
coryspiteri
in reply to: AJA14
OMG THANK YOU!!!!
