Cancel all or Overwrite all when saving Families
3 REPLIES 3
Base12
352 Views, 3 Replies
When Saving families to an existing folder (say, to update your custom content library), I cannot believe that there is no option to a) Overwrite All, or b) entirely cancel the process.  Rather, it's necessary to tap the Enter, (or Escape) key repeatedly to individually overwrite, or cancel each entry in the Family that may already exist in the folder you're saving to.
Thanks for your attention,
JP.
3 REPLIES 3
Lance.Coffey
in reply to: Base12
When using the Save As -> Library -> Family option, and specifying a folder that already contains some of the files that will be saved from the project, I am not seeing an option to Overwrite All or Skip all.
To work around this, I would suggest picking an empty folder, and then copy/move these files to the final destination using Windows (as these options should be available when copying in Windows).
Lance Coffey
Technical Support Specialist
Base12
in reply to: Lance.Coffey
Thanks for you answer, but your proposed work-around solution just isn't
acceptable by modern standards. The solution would be a simple
button/command to break the function and cancel it entirely. Nearly
every other Windows software program (including Windows Explorer itself)
has this function available.
What makes it exceptionally frustrating is that once you start the
process, there's no way to stop it short of hard power-cycling the
computer in the middle of it -- which is just ridiculous. Revit has so
many amazing features, but somehow has still managed to cling to a few
80's technology pitfalls that could be so easily updated. This is just
one example.
Thanks for your time,
JP. Bernier
Lance.Coffey
in reply to: Base12
There are a few ways to stop the operation once it has started. I am listing these in order of least to most impact (on the project / system):
- Hit the Cancel button on the status bar (bottom left).
Note: This can be a bit tricky to use as you need to hit this between overwrite dialogs (while the Cancel button is displayed).
- Stop the Revit process (using Task Manager or the TSKILL command).
- Restart the system.
I do agree that this behavior can cause a bad experience when saving a lot of families (especially if you have no recourse but to restart the entire system to stop the operation).
Product Feedback
Lance Coffey
