Show only
Search instead for
Simply select one of the grid lines and move it - the rest will follow (you
may have to use the key to get to it).
You can also rotate the grid by picking a grid line and rotating it.
The same tools can be used on a brick hatch pattern to change the coursing
in an elevation or section.
"david125" wrote in message news:6380633@discussion.autodesk.com...
> I'm new to Revit and can't find the aswer. Is it possible to shift a
> ceiling grid either during creating one after you've already made one?
