I am planning on using the full version of Revit for home design. However, I may at times need to open my files with Revit LT. Can files from the full version of Revit be opened in Revit LT?
Solved by DarrenP. Go to Solution.
yes read this from the help
Interoperability between Revit LT and Autodesk Revit
http://help.autodesk.com/cloudhelp/2014/ENU/Revit-LT/files/GUID-89BACB84-7B3F-44E3-A4A9-73507FAF23E3...
there will be limitations for certain things
DarrenP
Hello Darren P,
Have you encountered any errors before for files when working both on full revit and LT version?Thanks
