Can't see the furniture in plan, but it appears in 3D
4 REPLIES 4
7904 Views, 4 Replies
I am not very advanced with the Revit, and I have a problem I dont know how I can solve.
I made the building, and after I had to change the elevation levels, and after I did this, I copyed some furniture from the level 1, to the level 2. Some of the furniture was copyed the right way, but all the chairs from the plan are missing. I tought maybe they've been deletel, but I try put new chairs, and they also don't appear in the second level only. When I went to 3D view, i saw there are there, at the right level where they should be. I dont know why they don't appear in plan. And also I noticed the interior walls are grey, and not white in the plan.
Also, when I go to ground  floor, and put underlay level 1, I see the chairs there in the underlay, not at level 2.
I made this print screen maybe is easyer to understand.
http://oi40.tinypic.com/2jer2vk.jpg ground floor with level 1 underlay
http://oi41.tinypic.com/f1xl45.jpg level 2 with missing chairs
http://oi42.tinypic.com/14dow2c.jpg the chair appears in 3D at correct lvl 2
Hope someone can help me. Thank you!
4 REPLIES 4
Jason_S
Try changing the "Detail Level" for the second floor to Medium or Fine. Currently your screen shots show it as "Course" and the chairs maybe told not to display at the display.
To change the display go to the bottom of the screen and click on the "Detail Level:" icon.  See attached image.
Hope this helps.
in reply to: Jason_S
yes, it was that one! thank you so much!!!
This did not work for me even after changing the detail level
Jason_S
Is the category turned off?
Type VG and look at the Model Tab and make sure Furniture has a check beside it.  That turns the furniture off and on.  What other things have you tried or done to help you find out what happened if that doesn't help.
