I can't put my nested window family in a curved wall.
Does anybody know where the problem could be situated?
It has to be a normal straight window so I use my nested window families from other projects.
I compared my NWF(nested window family) with the ones autodesk provides with revit but I don't find the difference.
The NWF from autodesk work in a curved wall.
Kind regards
Maxim Bode
Hi, we are using standard PGT windows in our projects, but the only way to put the double windows was using two simple windows as shown in the attached image. I guess that the wall thikness could be the problem.
Thanks, Alex
Hello
I made a wall with a bigger thickness and the window stil doesn't want to do in.
With straight walls there is no problem.
What I did see was my old windows who were made just for one project (not nested) do fit in but I would like to use the nested ones otherwise I have to make all new window families for every window type I want in the curved wall.
Do you or anyone else know where the problem could be with my nested window family?
Kind regards
Maxim Bode
