Revit Architecture
Revit Architecture
Active Contributor
BobbyC.Jones
Message 11 of 22 (888 Views)
Re: can't print transparency from floor plan in revit 2013???
07-27-2012 06:06 AM in reply to: TroppoSA
The problem with the print with raster processing workaround is that it creates huge DWF files...ginormous even.  I am dissapointed that the update didn't address this issue.
Bobby C. Jones
New Member
RadDeering
Message 12 of 22 (876 Views)
07-27-2012 08:41 AM in reply to: Lance.Coffey
Lance:
We are experiencing this issue in our office. Is a solution for vector printing available yet? Printing using raster processing is not a real solution for our office because of the poor drawing quality and larger PDF file size.
Rad
Active Member
jarrodpirtle
Message 13 of 22 (837 Views)
09-06-2012 02:34 PM in reply to: TroppoSA
This problem extends to DWG export as well. Unfortunately I can't use the "Raster print" work-around for exporting to DWG. Any suggestions for exporting to CAD?
TroppoSA
Message 14 of 22 (826 Views)
09-06-2012 10:06 PM in reply to: jarrodpirtle
The possible work-around is to set disipline to structural in the plan views. but it won't work if you are not seeking exporting structural plans. it seems autodesk is too busy to fix this 'small' problem.
Active Member
jarrodpirtle
Message 15 of 22 (814 Views)
09-07-2012 08:28 AM in reply to: TroppoSA
As it happens, I'm already working with structural plans and I'm still having the issue. All the plans are set to Structural discipline. I have the floors set to 100% transparent and the structural framing that's partially, or completely under the floors is not shown in the PDF and not exported to DWG.
Product Support
Lance.Coffey
Message 16 of 22 (807 Views)
09-07-2012 09:37 AM in reply to: jarrodpirtle
If the structural framing is setup as an underlay in the view, try changing the view discipline to something other than Structural.
Lance Coffey
New Member
AdamVG
Message 17 of 22 (720 Views)
11-14-2012 01:49 PM in reply to: TroppoSA
The only way to get the transparency to print is to export it as an image. Then i just convert the image to a pdf.
Member
twm5068
Message 18 of 22 (628 Views)
01-17-2013 10:47 AM in reply to: Lance.Coffey
Any update on a solution or a software fix? We are still having the same problem and are unable to use Revit 2013.
TroppoSA
Message 19 of 22 (598 Views)
01-29-2013 08:52 PM in reply to: twm5068
A hotfix just came out. download it from here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21147820&linkID=9273944
Did a couple of quick tests, it worked. so reckon case can be closed here.
New Member
danielqu
Message 20 of 22 (503 Views)
04-04-2013 11:03 AM in reply to: TroppoSA
I am having an issue I just noticed and wonder what I am missing.  It seems this should be working.  One attachment is a screen pic of my compiled view on the sheet itself.  The other is a pdf print of same sheet.  You will note that in the printed pdf does not show what the screen pic does.  Why?  Any input help appreciated.  This seems like this is what the initial post was about, yes?
