Can't move down wall foundation?
2 REPLIES 2
diesellam
2562 Views, 2 Replies
See the attached PDF file.
I can't move down the wall foundation.  (The highlighted piece.)
What's the reason of it?  The properties of the wall foundation doesn't have the offset feature.
2 REPLIES 2
Alfredo_Medina
in reply to: diesellam
Probably, it's one of those foundation items that Revit sticks to the wall, meaning that to set the foundation at a lower elevation, you need to edit the base constraint of the wall, instead of trying to move the foundation in a section view. Then the foundation moves along. I hope it helps.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
diesellam
in reply to: Alfredo_Medina
Cool.  It worked.  Thanks.
