See the attached PDF file.
I can't move down the wall foundation. (The highlighted piece.)
What's the reason of it? The properties of the wall foundation doesn't have the offset feature.
Solved by Alfredo_Medina. Go to Solution.
Probably, it's one of those foundation items that Revit sticks to the wall, meaning that to set the foundation at a lower elevation, you need to edit the base constraint of the wall, instead of trying to move the foundation in a section view. Then the foundation moves along. I hope it helps.
