Can't export .fbx format from Revit
1 REPLY 1
mlow55
5026 Views, 1 Reply
I am currently using Revit Architecture 2012 and am trying to export a project file in a .fbx format to start using Autodesk Showcase which I just downloaded a free trial for. For whatever reason, Revit won't let me export any file in a .fbx format. Instead of being able to click on that as an option, it's greyed out. Is there an update I need to download or an fbx plug-in I need to get to utilize the fbx exporting function??
PS: I've put myself in the 3D view which I know can be an issue of why the fbx export function is greyed out.
Thanks!
1 REPLY 1
blake.avery
in reply to: mlow55
You may be in a plan view or elevation view. You need to be in a 3D view to export as FBX from Revit. Hope this helps.
-Blake
Rail Community
