Can’t edit the room tag,
6 REPLIES 6
JamaL9722060
5201 Views, 6 Replies
It is very confusing when it comes to edit families in the Revit. For example, the tag of the room has a “rectangle” but in the edit mode I can’t find it.
Where might be my mistake?
Thank you
Best
Jamal
Jamal Numan
6 REPLIES 6
CoreyDaun
in reply to: JamaL9722060
This one has confused many. The most likely problem is that the Annotations are turned off in the Room Tag Family. See image below.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
JamaL9722060
in reply to: CoreyDaun
Many thanks for the answer.
but couldn't know to get the dialogue box you have provided in the screenshot?
Jamal Numan
CoreyDaun
? Visibility/Graphics Overrides is probably the most commonly used dialog interface in Revit. The default keyboard shortcuts are "VV" and "VG", or you can find it on the View tab of the ribbon, or in the View's Properties. You then have to switch to the 'Annotation Categories' tab.
JamaL9722060
Many thanks for the very informative answers.
I check it on but still the rectangle doesn’t appear when we are the edit mode
What might be the problem?
Jamal Numan
CoreyDaun
Access the Visibility/Graphic Overrides dialog from within the Family Editor. So press "VV" while you are editing the Room Tag family.
JamaL9722060
Great! it works. many thanks for the help.
Jamal Numan
Rail Community
