Revit Architecture
Revit Architecture
9 Kudos
Post 1 of 7
Can’t edit the room tag,
606 Views, 6 Replies
10-04-2012 12:08 PM
It is very confusing when it comes to edit families in the Revit. For example, the tag of the room has a “rectangle” but in the edit mode I can’t find it.
Where might be my mistake?
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Access the Visibility/Graphic Overrides dialog from within the Family Editor. So press "VV" while you are editing the Room Tag family.
998 Kudos
Post 2 of 7
Re: Can’t edit the room tag,
10-04-2012 12:21 PM in reply to: JamaL9722060
This one has confused many. The most likely problem is that the Annotations are turned off in the Room Tag Family. See image below.
9 Kudos
Post 3 of 7
10-05-2012 02:28 AM in reply to: CADastrophe
Many thanks for the answer.
but couldn't know to get the dialogue box you have provided in the screenshot?
Firefox 20.0,
Kaspersky 2013.
998 Kudos
Post 4 of 7
10-05-2012 05:53 AM in reply to: JamaL9722060
? Visibility/Graphics Overrides is probably the most commonly used dialog interface in Revit. The default keyboard shortcuts are "VV" and "VG", or you can find it on the View tab of the ribbon, or in the View's Properties. You then have to switch to the 'Annotation Categories' tab.
9 Kudos
Post 5 of 7
10-05-2012 09:00 AM in reply to: CADastrophe
Many thanks for the very informative answers.
I check it on but still the rectangle doesn’t appear when we are the edit mode
What might be the problem?
Firefox 20.0,
Kaspersky 2013.
998 Kudos
Post 6 of 7
10-05-2012 09:27 AM in reply to: JamaL9722060
9 Kudos
Post 7 of 7
10-05-2012 10:19 AM in reply to: CADastrophe
Great! it works. many thanks for the help.
Firefox 20.0,
Kaspersky 2013.
