Guess what. More than a decade later this is still a problem. Yes I am still using model patterns, and no you still can't adjust the pattern on the end of a wall. Maybe sometime in the next decade this will get addressed.
Hi, I've got this same issue while working here (I wasn't able to align a surface pattern to a wall).
Here's a solution that worked fine for me:
1. After creating the material, with a model pattern, apply to the desired surface.
2. If you can't se the surface pattern lines, change your visual style to Shaded.
3. Then, if you still can't see the pattern lines, right-click on the desired surface, then go to Overide Graphics in View > By Category > Surface Lines > Check Visible box, then click OK.
4. Now you are able to select the surface pattern lines and align it to what you want. Remember using Tab key to accurate selection.
Hope this might be helpful.
See you.
Nope. Doesn't work.
and it's Surface Patterns, btw, and their visibility was never the problem. Besides, they're on by default.
No, I think the problem here is a fundamental flaw in whatever engine AD is using to render the lines in our views and they can't fix it. Even with the Location Lines set to a face a surface pattern will always lock to the center of the wall. The only solution is a filled region in the view.
Hi all,
This item has been annoying me for years! AD has not fixed it and I do not think they ever will.
On a positive note, one workaround I have been using for a while is the rotate command. The pattern model lines at the end of a partition cannot be moved, but they can be rotated. For example, rather than creating a new material than has the same material tag as the other to remove a vertical line that is not desired, one example of how to get around this but not my favorite, you can move your cursor along one of the horizontal lines to a point outside of the partition end, select your rotation origin , and then rotate the vertical line outside of the partition end. You will need to be cognizant of the vertical line repeat width and select your rotation origin according to that width.
Has been a quick way to get around this problem for me and I hope this helps save some time with future modeling.
I had this problem and it turns out the graphic I was using was a drafting pattern and it needed to be a model pattern. This can be changed by going to edit type, edit structure, select material with graphic, then click on your graphic pattern and on the pop up window you can select 'pattern type'. If you want to be able to align the pattern select model type.
Refer back to the method you used to create the pattern itself. I faced the same problem because I drew my tile pattern as lines and then used "Array" to copy the lines at the desired distances, which converted my lines into "Detail Groups." Once the lines become grouped, you won't be able to grab and align them later in the interior elevations.
I created a new pattern with only line (no groups) and that fixed the problem.
