Can't Change Scale
8 REPLIES 8
Message 1 of 9
tonkata
78695 Views, 8 Replies
Can't Change Scale
My Site Plan Scale is greyed out, what could be causing this?
8 REPLIES 8
Message 2 of 9
tonkata
in reply to: tonkata
Don’t you just love when you accidently stumbled on the problem and find your own solution!
I had a View Template applied to the Site Plan, which seems to deactivate the ability to re-scale the view Smiley Indifferent
Message 3 of 9
Yes, I suppose this is the cause....
Perhaps : View Scale is checked in View Template....uncheck it in order to can choose another scale
Constantin Stroescu
Message 4 of 9
in reply to: constantin.stroescu
What about if you donot have any template?
My scale is to 1:200
but when I inset the sheeon on the title block, I can change the scale, but the title does not change the scale.
and still shown at 1:125 on grey as the view title
Message 5 of 9
It could be that your sheet properties for scale is only text notes & not a parameter assign for 'scale'. For your sheet to reflect back the scale, you can try add label/ edit label and change it to 'scale'.
Message 6 of 9
katarina.blatnik
we use scale
1:10
1:20
1:25 ??
1:50
1:100
1:125 ??
1:250 ??
1:500
1:1000
1:5000
how can i change or add scale to revit? Is possible?
Katarina
Message 7 of 9
simply type the new desired scale:
Constantin Stroescu
Message 8 of 9
Thanks, i didnt see.... 😉
Message 9 of 9
mdenum
It works! Thanks a lot😊
