I have set up the curtain wall guides and tabbed through the panels to select the panel I want to put a door on. For some reason, when I select the panel and try to change the properties, no doors appear in the drop down menu. I have several door families loaded and in use in my model already, including the default revit ones and some downloaded families yet they don't seem to show as an option to replace the selected panel with. A previous model didn't have this problem using the same method. Are there any settings that I am missing or any fixes?
verify these:
Constantin Stroescu
Please follow the attached images which are very much helpful for your problem.
1. Image-01:- Simple Curtain Wall with Mullions.
2. Image-02:- Use Tab for select the glass segment where you want to fix a door.
3. Image-03:- After selecting a glass segment to Properties > Edit Type > Type Properties > Load > Door Family > Select Curtain Wall category glass single or double glass door > Ok > Ok
4. Image-04:- Curtain Wall with Curtain Glass Door
5. Image-05:- Fix bottom mullion and select the door's bottom mullion and delete it.
6. Image-06:- Curtain Wall with Door is ready for use.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Please find the rest attached files for Curtain Wall Glass Door fixing.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Hello I have problem with Curtain Wall Door that I try to load from Load Family but Its not work. I can't open Curtain Wall Door from Loading Family. I'm using 2016 Version.
