Hello again,
I've created a room schedule in my template. Now while I was working on a project in that template, I couldn't add a new row. If I want to add rows, I have to create a new schedule and add rows in there and then it works.
Is there any solution?
My regards,
Romano Bruining
Povše & Timmermans architects • engeneers
Solved by yradyk. Go to Solution.
Solved by Romano1991. Go to Solution.
No idea. You should be able to create a new row, either with "New" button or with Right click > New row. It is hard to tell what might be happening based on this information.
What information do you need? I'm not a pro but if you could explain what you need I think I can handle it (:
Thanks for your reply!
Were you doing anything specific at the time I no longer was available?
I tried to recreate the situation and there was not anything I could to do make it not show up.
Do you have all the latest service packs installed (I always ask this question)? Just want to make sure it is not cause by something else...
LD
I don't think I've installed them, but I already solved it.
I created a new schedule with the same categories and now it works.
Thanks anyway
I ran into the same problem.. figured that when " itemiize each instance" under sorting is unchecked you can't add rows
I'm having the same problem, and my "itemize every instance" box is checked...
When you create new schedule - (on the right side of the dialog box under the schedule name) if you have "Schedule building components" checked, then you can't manually add new rows to the schedule but if you check "Schedule keys" you can manually add the rows. That was the fix for me.
Make sure there isn't a hidden column that is effecting the sorting as well.
I could only add a new sheet name at the top of the list but couldn't insert it into the sheet grouping i wanted.
Column one was hidden in this persons template and it was where you designated which sheet grouping you wanted to add the new sheet into.
Sorry do you know how you can do this even after you have made your schedule?
Have you created the schedule in Revit 2017 or have you upgraded your model?
Due to slight changes in objects and properties it could affect the schedule abilities...
Francois-Gabriel Perraudin
BIM management and coaching
Done a few tries for you guys...
TO me two options in the PP can affect the "new" row button:
Nothing else to my knowledge...
François
I personally don't understand why Revit will let you add a new data row to a Room schedule (or any Quantities schedule) anyway. I mean, if you want a new row in a Room schedule, you OUGHT to have to create another Room element, right? I create a new row an a Room schedule, and it gets a number and a name, but nothing exists in the project to reflect it. Try making a new row and then clicking on the Highlight in Model tool. You can't, right? Because no room was created. It's dumb.
Key schedules? Sure. Add new keys.
Sheet lists? Sure. Adding a row actually creates a new sheet.
Note block? Knock yourself out.
Imagine creating a new data row in a View List, for example. It's stupid. Create another view and THEN it will have another row in the schedule. Duh. This logic applies to Room schedules the same as it applies to Door schedules and the like.
Right? I mean, am I missing something here?
Key Schedules are not Component Schedules. If you're manually adding blank Key rows and typing component information in to them so as to imitate a Component Schedule, you're BIMming wrong.
My thoughts exactly, @chrisplyler. Add another element and a new row will be added.
@FGPerraudin @chrisplyler @Sahay_R
Thank you for your replies much appreciated.
The situation was I made a component in a family.
However part of my component wasn't steel which was the focus of my schedule.
So I wanted the schedule to only show only the volume and calculationsfor the steel part.
I didn't want to make a new family again.
So I wanted to add a new row where I could manually enter the volume of the part of the component I wanted.
And then using sorting/grouping to get rid of the previous data on the whole component.
I managed to add a new heading which created a new column, so I made this a Volume instead, copied my volume data unto it.
And then put the data I wanted for that component to represent steel
Then deleted the original volume from my schedule.
Thanks once again for your explanations much appreciated, I am getting a better understanding that schedule isn't just excel so there are certain restrictions.
Take care
Just to be clear, a schedule filter identifies criteria for items that will REMAIN in the schedule. Every item that does NOT meet the filter criteria gets excluded.
