I am trying to extend a stair stringer past the start of the stair tread. See attached file. I can't seem to get it. What am I missing?
Thanks for the help
Solved by Chris.Aquino. Go to Solution.
At this time, the only way to extend the stringer on a stair is to add the piece you want using an in-place mass or component, then modify the line work. We understand that this may not be the preferred workflow, but this is really the only way to do it.
This link is setup for you to submit feature requests, or feedback, directly to our Development group.
I encourage you to use the feedback link as our Development group is always interested and would like to hear your feedback directly, since you are better suited to state the business case for a feature request.
