Hi all,
I have a commercial-type flat roof and need to add roof drains to the center of the roof. What I want is for Revit to be able to tell me based on inputting a desired area (based on IPC) how many roof drains I will need. And I want this to be dynamic, incase the roof changes that it can recalc that.
I hope this makes sense. Having a Civil 3D background, the closest thing I can relate it to are parcels. I specify a total area and subdivide that based on desired area. Same concept for roof drains. I know at a certain roof area, that my horizontal pipe size needs to increase, which will be a problem because the walls cannot accomodate that size. So, by decreasing the area, I can get to the area and thus the correct roof drain size needed. And I haven't even addressed parapet wall height and the needed cals for that to be figured into the roof drain area calc. 🙂
So, can Revit do this? If so, please elaborate.
I haven't tried but may be you can explore this quick observation: you can use the room seperator or area boundary line .Tag them to see the areas instantly & if the boundary lines are locked with respect to Roof lines & Reference planes, they will change according to the roof changes.
Sorry for not able to eloborate for now...
You can create a roof schedule and include the area parameter from roofs. Then create a calculated value for drains and put in your formula for the amount of roof drains needed.
So in this example i am grabbing the area from the roof element and then created a calculated value of "Drains Req'd". I used a formula to get the number. Area / 300 (I just picked a number out of the sky). I alos included the "roundup" function putting my formula in () so I would get a whole number rounded up from the result of the formula.
