CAN NOT EDIT THE SHEET IN REVIT THAT WAS EXPORTED FROM AUTOCAD
1 REPLY 1
mahesh.kadiyala
538 Views, 1 Reply
Dear Team,
  I cannot edit a sheet in a revit file that sheet was imported from AUTO CAD.I had text in that sheet, i need to edit that text.
Please Provide me the solution as soon as possible.
Mahesh
1 REPLY 1
you can do like this:
  1. if you import a Model Space in one of your Views, select the imported entity and apply a Partial Explode - the text will became Editable
  2. if you import a Layout, then do it into a Revit Sheet ( insert into a sheet) - only the text from layout will be imported.....apply a Partial Explode - the text will became Editable
But , in fact , Explosion of a cad imported file is  not advisable because it increases the file to much.......
Constantin Stroescu
