Can I "remove" an opening from a roof...?
2 REPLIES 2
2361 Views, 2 Replies
Hi all.... I've cut an opening in a roof - can i "fill" it back in or remove it? TIA Adam
2 REPLIES 2
With an opening? Just select the opening and delete it. With a inner loop in the roof sketch? Edit the roof sketch and delete the opening sketch. If you need the hole for existing/demo, you can draw another roof in the hole and the two roofs can then be joined with the join geometry tool. "Revit_Noob" wrote in message news:41647608$1_3@newsprd01... > Hi all.... > > I've cut an opening in a roof - can i "fill" it back in > or remove it? > > TIA > > Adam >
Thanks Aaron.... i'll try that.
