Revit Architecture
Revit Architecture
Active Contributor
rlabib
Message 1 of 7 (1,672 Views)
Can I create a filled region on sheets ( hatch)
1672 Views, 6 Replies
01-21-2013 06:17 AM
I'm trying to add a hatch on a sheet , but the Filled Region button is gryed out ??? any ideas
Marlec
Message 2 of 7 (1,665 Views)
Re: Can I create a filled region on sheets ( hatch)
01-21-2013 06:56 AM in reply to: rlabib
I think you can only make filled regions on views (any views in the project browser)... not sheets...
I think you're like me a CAD user gone Revit... a lot of thinking to change...
CADastrophe
Message 3 of 7 (1,661 Views)
01-21-2013 07:01 AM in reply to: rlabib
You'll have to create a Filled Region within a Generic Annotation Family and then load that into your Project for use on your Sheet Views. You can use constraints and instance parameters to control the boundary of the embedded Filled Region in the Project.
Active Contributor
rlabib
Message 4 of 7 (1,630 Views)
01-22-2013 06:00 AM in reply to: rlabib
Thanks everyone, what I did is I created a drafting view that has some details and filled regions then I put that on the sheet.
New Member
ShannonZ
Message 5 of 7 (1,332 Views)
09-13-2013 05:48 AM in reply to: rlabib
how did you do this? I am very new to Revit and can't figure a drafting view? (I'm using MEP)
CADastrophe
Message 6 of 7 (1,322 Views)
09-13-2013 06:30 AM in reply to: ShannonZ
Hi Shannon, and welcome to the Discussion Groups!
Drafting Views are created by going to View tab » Drafting View. It would probably be easiest to set the drawing scale to whatever your Plan View is set to. Before you create the Filled Region or Masking Region, go to Annotate tab » Detail Line. Draw a couple of random Detail Lines on this View so you can better locate it on the Sheet View.
Open your Sheet View. Locate your new Drafting View in the Project Browser, and drag & drop it from there onto your Sheet View. Overlay it on top of your other Viewport. Next you'll have to get rid of the View Title, so select the Viewport of the Drafting View and click "Type Properties" at the top of Properties. Click "Duplicate..." and name this new Type to something with "(No View Title)" and click 'OK'. Now Set 'Show Title' to "No" and click 'OK'.
Now, back on your Sheet, select the Viewport of the Drafting View again, right-click, and select "Activate View". This will enable you to delete those random lines and draw in whatever Filled Regions or Masking Regions you need. When completed, right-click and select "Deactivate View".
If you run into any issues or problems, don't hesitate to ask!
New Member
ShannonZ
Message 7 of 7 (1,316 Views)
09-13-2013 06:45 AM in reply to: CADastrophe
That was SO much help! Thank you very much! This stuff is just so not cut and dry! (I suppose I used to think about AutoCad too :smileyhappy: )
Again, Thank You! I may be back as I keep running into these little problems!!
Shannon
