Revit Architecture
Revit Architecture
5 Kudos
Post 1 of 4
Can I apply a material for rendering to a generic wall?
1121 Views, 3 Replies
08-19-2010 04:27 PM
I've created some generic walls and I wanted to overide the material but I can't find a way to do it.  I thought I could do it in revit arch 2010 but using properties and edit type but I don't get the materials selection using revit arch 2011.
Employee
110 Kudos
Post 2 of 4
Re: Can I apply a material for rendering to a generic wall?
08-22-2010 07:22 AM in reply to: David125
You can use the "Paint" tool to paint any material onto a surface (wall or any other).  If you want to change all the walls at one time yoju can change the appearance of the "Default Wall" material.  This is the material used by the Generic wall types.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
New Member
0 Kudos
Post 3 of 4
08-26-2012 10:52 AM in reply to: David125
You may insert a new layer as  a finish one ,and
 then aplly the material you want to.
                                            gerardo
New Member
0 Kudos
Post 4 of 4
08-26-2012 11:37 AM in reply to: David125
In my former message I proposed you create a new finish layer , but you may also change the whole wall , jusy apply the new material to the Structure1 layer,that's  even faster.Now you have three different options.i hope someone is good for you.
              gerardo
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
