Revit Architecture
Distinguished Contributor
2 Kudos
Post 1 of 2
Camera View
352 Views, 1 Replies
12-10-2010 04:48 PM
Is there a way to pull a camera view into a sheet and change the size of the camera without actually cropping the picture?
23 Kudos
Post 2 of 2
Re: Camera View
12-13-2010 06:03 AM in reply to: kate_vanhout
To scale the camera view without changing the crop of the picture, you can do the following:
  1. Open the camera view and select the crop boundary.
  2. On the Modify | Cameras tab of the Ribbon, select the Size Crop tool.
  3. In the Size Crop dialog > Change section, select Scale (locked proportions).
  4. Adjust the Model Crop Size measurements as desired.
Selecting the Scale (locked proportions) option will scale the view to your measurements rather than just adjusting the boundary itself. This procedure can be done in the camera view itself or once it is placed on the sheet.
I hope this helps!
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Post to the Community
New Post
