I can't figure out why Camera Views is different from all other views in Revit. It is simple not possible to add a view reference, or a tag etc. to reference to a camera view.
It can't be true that i am the first one to see this problem?
Of course I can put in a 'dead' symbol to show where it is in plans, but that's simply not the same...
Some time ago, learning a previous version, I was wondering the same question.
Would like to know what others say about this issue and/or the answer...
I looked around online (using the words Tag a camera view Revit), and found the following pages with information on this:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=21094
http://www.revitcity.com/forums.php?action=viewthread&thread_id=21601
If you want to make annotations on the camera view, I also found the following page:
http://aectechtalk.wordpress.com/2011/05/06/annotating-3d-views-in-revit/
If you would like to submit a feature request to our development group (regarding an option to tag or reference a camera view), you can use the following feedback page:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Once the Camera View has been added to a sheet in the drawings, I place a View Reference tag in the plan and then use a simple leader (blank generic annotation) pointing in the general direction that the camera is pointing. The leader won't update if the angle of the view changes, but at least the reference updates if the view moves or changes name in the project.
