callouts not visible in segmented section view
1 REPLY 1
188 Views, 1 Reply
When creating callouts of a section that is segmented in elevation view, I
get the error message that "none of the created elements are visible in
section..You may want to check the active view, its Parameters, and
Visibility Settings." The callouts will be visible however if that same
section is unsegmented. What am I doing wrong and how do I fix this?
1 REPLY 1
Did you check your visibility graphics to make sure that the model elements are visible. Also when you segment the callout is the model elements visibile in both segments.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
MasterGraphics, Inc.
