Callouts for plan view
2 REPLIES 2
Jleibold
2754 Views, 2 Replies
Hello All,
Durning an online training segment, there is a learning section using callouts for floor plans.  It's straight forward but when I make a callout on level 1 for an enlarged floor plan, the view is created in "details views - Detail 0 and not "floor plan view - callout for level 1".   Is this something to do with the template?  How do I change or fix it.
Thanks in advanced
Jeff (novice)
2 REPLIES 2
loboarch
in reply to: Jleibold
It has to do with what you have selected in the type selector when you place the callout. Select a floor plan callout before you place it and it will go to the correct spot in the project browser.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Jleibold
in reply to: loboarch
Thanks....duh...I now remember the type selector options....
I had the project browers & properties windows set up to tab between the menus & not the properties over the project browser...
Again, thank you....
Jeff
