Callout
5 REPLIES 5
513 Views, 5 Replies
Callout
I have an overall building plan 3/32" = 1'-0".
I have another floor plan of the SAME building at 1/8" = 1'-0".
When I do a callout on the 3/32" overall building plan, how come the callout doesn't show on the 1/8" floor plan?
Is the only solution to reference views. The only reason I don't like that is
1. it's extra work
2. I want the callout bubble to be consistent thoughout all the sheets and if someone else jumps on this project it'll be confusing for him how everything is referenced.
Thanks.
5 REPLIES 5
LisaDrago
Did you check the properties - hide at scales coarser then:
see image....
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
I'm aware of this option for sections. But I was interested to see if a similar option was available for CALLOUT BUBBLES.
LD, let me know if you're aware of one. Thanks.
LisaDrago
Woops! - sorry about that...
to my current knowledge callouts do not work that way... i believe they are considered annotative... which are view specific.
LD
ljhudson
Does this mean Plan callouts will only show in the plan it was created in?
LisaDrago
in reply to: ljhudson
Yes - if you are on the first floor plan and you place a callout - you will only see that on the first floor plan you placed it in.
If you have a copy of the first floor plan - it will not show up there.
If you need it to show up in more then one view and do not want duplicate views - when you start the callout command look in the options bar below the ribbon - check the box for Reference other view and then in the pulldown list - select the other callout. WHen you place it it will reference the first callout.
I have attached an image for reference.
LD
