Just loaded revit 9, all fine - but - callout from a plan of door jamb (detail callout) gives me a detail with a cut plane way above the original plan level. I needed to turn off the roof &wall visibility to see it the window. If the callout is a floor plan callout it works fine. Any ideas here. have tried it out on separate files with same result.
