Solved by constantin.stroescu. Go to Solution.
Usually the last tread is considered to be the next floor(that's why in my example you have 23 riser but only 22 treads - the last tread is the next floor).
If you want to have a tread on the next floor , then ,you have to uncheck End with Riser option...
Doing so, you'll obtain the last trade on the next level.
Constantin Stroescu
I fully understand what you say, but not what I meant.
I mean, if I draw a ladder, Revit is getting me this with all steps of the same measure (say 19 cm), but the last step measured more than 19 cm sometimes 30 or 38 cm, and that's what I want to correct.
In the picture I attached in my first message, the distance between the last step and the next floor is 38 cm.
It is what I can not explain.
I understood wrong your first post...
If you want to obtain what you desire , I think you have to look for two things:
for details look on my recording:
https://chronicle.autodesk.com/main/details/fd55085b-f4c7-4221-8b3c-27d031db666e
Constantin Stroescu
wow
to me this is perfectly clear. Although I have not been able to try it since I have the 2012 version of Revit, and as I understand it, is one of the latest news from the 2013 version.
Thank you very much for taking the time to make the example even with my own measurements. People like this make a better world!
Thank you very much God bless
Friend, you could have a look at this?
http://forums.autodesk.com/t5/Revit-Architecture/contiguous-platforms/td-p/5058376
have a look at:
https://chronicle.autodesk.com/main/details/682281f8-e56f-4056-8981-a33bb2b355f9
I hope it could help you
Constantin Stroescu
