Calculated Parameters
1 REPLY 1
Womack
119 Views, 1 Reply
What would be the Syntax to create a parameter that would return 1 if a visibility parameter is on, and 0 if it is off. I'm trying to create schedulable items to tell if an end cap is visible or not.
1 REPLY 1
in reply to: Womack
Set a shared param. as an Integer and then use the formula "=IF(Visible, 1,
0)" where visible is the Yes/No param controlling the object visibility.
wrote in message news:4922249@discussion.autodesk.com...
