I have noticed an issue and had a question about process.
I have:
1. Linked Cad Center to Center with Project North current in Site View
2. Rotated and moved the cad file to the correct project north location and orientation
3. Unclipped PB and SP
4. Aquired coordinates from the Cad dwg
5. Reclipped PB SP
Everthing works fine
If I unload/reload the dwg with the view set to True North the dwg rotates out of postion based on the original rotation.
If I reload with the view set to Project North the CAD file orients correctly
Is there a general best practices for keeping the drawing static. I've read the blogs about using a dummy xref file.
Thanks!
Marla
From your workflow, steps 3 and 5 are not necessary. Try again, with 2 files that have not been related yet with shared coordinates, and without those steps.
Marla-
I have seen this problem on several projects at this point. I believe you are seeing a Revit bug with linked cad site plans used to establish shared coordinates that goes way back. Apparently Autodesk is aware of the bug I've learned, from reading many forum posts going back to 2007.
This post has a workflow to get around the bug. So far, Leaving a maintenance site plan view set to project north is holding my current project together:
AUGI-Thread: importing DWG surveys & acquiring coordinates
Let me know how this works
Good luck!
Firstly thanks for linking to my post on the AUGI Forum - posted 7 years ago.
Secondly I am posting here because I cannot believe that Autodesk have not sorted out a simple bug on linked DWGs.
The screenshots below shows how shared coordinates just do not work if the view is set to True North
