Builidng “title blocks” in the Revit,
3 REPLIES 3
JamaL9722060
1592 Views, 3 Replies
My issue is to have the same title blocks I use in the AutoCAD. I’m not sure about the best way to build title block in the Revit. I tried to “duplicate” a ready to use sheets but sounds not to work!
What might be the best practices?
Thank you
Best
Jamal
Jamal Numan
3 REPLIES 3
LisaDrago
in reply to: JamaL9722060
You can start a new title block on the correct size sheet - then import your existing AutoCAD title block in and use the pick lines to recreate the 'drawing'.
Use text for any static text - words that will never change.
Use Lables to create parameters for text that will change - like sheet name and number. project name and address - etc.
you can bring in an image for your logo.
I know this is pretty short - but it will get you started.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
JamaL9722060
in reply to: LisaDrago
Many thanks for the help. This is useful.
Best
Jamal
Jamal Numan
