building physical model: laser cutting whole project: walls, floors and roofs
1 REPLY 1
Rybin-Owner
1266 Views, 1 Reply
Autodesk Revit is great except the step where I try to convert or export the whole project into laser drawings, in order build a physical model.
Obviously there are many floors, walls and roofs or planes; each requiring its own flat drawing or dxf file for laser cutting.
Every time I have had to completely redraw the project in another program.
I did some research but found no solution.
Any suggestions?
1 REPLY 1
ARCH-SADEQ
in reply to: Rybin-Owner
I have the same problem and I also, don't know how to send it from dxf to laser cutter >> it should be like in flat 2D to be able for laser cutter to cut it
