I created a building pad to cut the ground through my finished basement. In my section views, the building pad is covering my other model elements such as doors, walls, furniture, etc that I have in my basement which I want to see. Thank you.
Maybe the pad is too thick? Select the pad > Edit type (or Type properties) > Structure > Edit : check the thickness.
I would first make sure your pad is on the correct level and it’s the correct thickness. If it’s still blocking content you can right click on the pad and choose Hide in View – Elements. The pad will be hidden and you should be able to see everything.
Thank you,
Alan:
I have a question about pads that comes up whenever I use them:
Are they intended to just be used as a cutting element, and then hidden, as you suggest? Or do people give them thickness and then use them to represent something, like a soil layer or slab, etc?
In general, there's more than one way to do things, but what is the ideal/intended function or use of a pad?
bt
As you pointed out many tools in Revit can be used in many ways. That said I typically use Pads to denote how topo (grade) interacts with my buildings. A building may have multiple levels below grade that can be full basement, partial basement or crawl spaces. You may also have retaining walls that interact with the topo (grade) at different elevations. Pads allow you to show all these differences in a precise and defined way. You can have many pads in the one drawing depending on needs/requirements.
When you have a moment please review the material in the below link:
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS46b90c3cb2c58cad535b58fc7fa5f227-7ff0.htm
Let us know if this helps.
Thank you,
Alan:
Do you tend to hide them, or do you also use them to represent site or building elements? I just go back and forth on that...
bt
I want to ask a question about pad too, when I use spot elevation tool to add a elevation synbol in plan(leve +0.00m) have this pad (pad thik 200mm) , it show -0.200m what must I do to display +0.00?
Thanks for all the input. I was placing it the first floor level instead of the basement.
BT,
Typically I hide Pads as I do not use them to represent building elements. That's not to say one can't use them in a different manner. Like me, if you find a way that works well for you I'd say stick with it. At least for me, consistency in my drawing sets is very important. This is achieved by finding goods ways to convey information with the tool available.
Hope this helps and thank you,
bt1138 wrote:
Alan:
bt
I am not Alan but I have an opinion on pads. I usually end up hiding them. I use them to cut the toposurface so my building will fit in context and then end up using a floor. There are a couple of reason I end up doing this.
I wish pads were more versitile because it seems like a big pain to have to place the same basci object 2x. Plus you have a chance of intorducing erors like this.
I assuming you have the Pad at the correct elevation, example: Pad created on Level 1 and the Pad thickness is 200mm. The default setting on the Spot Elevation tool is Actual (Selected) Elevation. If you place a Stop Elevation Tag on the above Pad it should read 0’-00” (or whatever elevation Level 1 actually is in your drawing). If this is not the case you will need to check the Properties of the Spot Elevation Tag.
Do the following:
Highlight the Spot Elevation Tag.
Look in the Properties Box for Display Elevations (under Text), and note what it currently says.
Click the text to the right of Display Elevations and you will get a drop down menu.
Choose the option that suit you needs.
Click Apply.
I hope this helps, but let us know if you need more information.
Thank you,
Thanks for the replies.
I have also ended up hiding them, most of the time. But since pads can be given a material and thickness, I keep thinking I must be missing something - that there might be a different way to work with them...
bt
