style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<Arjun@IDS> wrote in messageHi,
href="news:6116037@discussion.autodesk.com">news:6116037@discussion.autodesk.com...
A). I calculated rooms area by Room schedule and got gross total 13726 SF. B)
I calculated Gross area by Area Schedule (Gross Building) and got 15054 SF.
Why the difference between these two values? I want to calculate Gross
Building Area in my application written in c#. To get room gross area, I sum
up each room area through my code but didn't find any way to get building
gross area. The above values I got through revit design view but I want these
values using RevitAPI.dll . I searched in SDK also but no example for building
gross area found. Thanks in advance.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
<Arjun@IDS> wrote in messageanyone
href="news:6117775@discussion.autodesk.com">news:6117775@discussion.autodesk.com...
with code snippet or idea on this ??? My deadline is reaching to
throat!!
<Arjun@IDS> wrote in messagethnxs
href="news:6123358@discussion.autodesk.com">news:6123358@discussion.autodesk.com...
cdv, I had not tried many options for this. It would be great help to
calculate gross area independent of rooms. I do need to do in this fashion.
cdv, could you please tell me the steps, I have to follow in my code to find
out the gross area!!! thnxs again.
I am looking for the same information. Using the API, I want to be able to get the Floor Gross Area (outside of exterior wall) and the Floor Rentable/Measured Area (inside of exterior wall).
First, is it required to have Area Plans to get these values? If not, where can they be queried from?
If it is required to have two Area Plans to get these values, is there an example of finding the appropriate area plans and how to get the area value from them?
