Hi, I'm using Revit Architecture 2013. It looks like my Building Element Mode button is missing and I can only run conceptual mass energy analysis. Am I missing a plug in or something? Let me know if you know the solution. Thanks.
Solved by Mohammad_Asl. Go to Solution.
Please follow the attched instructions. If you need to know more about this then please click on F1 for Revit 2014 Help.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Thanks for the reply, Subhra. It didn't work for me. Is it a new feature on revit 2014? I'm using 2013 and I don't have the "building element button"
even after signing in.
You are right. Building ELement Mode is a feature added to Revit 2014 and later versions. Unfortunately there is no way to have this option in Revit 2013!
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
