I'm trying to export Revit into Navisworks Simulate but there's no Navisworks tool in External tools. I did a full install of the Design Suite and checked Control Panel/ Programs/ Programs and Features for " autodesk navisworks simulate 2013 exporter plugins" but they're not installed. Are the plugins included in the Suite or do I download them from Autodesk? Thanks
You do not need to export Revit to open in Navisworks (new in 2013). It now natively comes in and will save as a nwd/nwf as needed.
LD
The Navisworks exporters will normally install with Navisworks. However, if they did not load, you could manually download and install them from the following link:
Autodesk Navisworks Exporters 2013 Multilingual Win.exe
http://usa.autodesk.com/getdoc/id=DL20458011
